Refueler
This defies logic ...
Picture a mainsail with bolt-rope to boom and mast track slugs. It has a standard eye in the tack of the sail...
The gooseneck end of boom has an eye bolt that lays in line with boom .. that is the 'hole' is 90 deg to the boom.
This is not first time I have tried to use a standard D shackle ... the tack eye and boom eye are same orientation ... but when sail is hoisted - the shackle twists and it does not work. It needs a 'twisted D shackle' that is a shackle that twists through 90 deg ...
Go on you Einsteins work that one out !!
I have tried ordering twisted shackles - but the sizes are all to cack ! bid enough - but 'jaw size' is limited. usually I e4nd up using two shackles combined to do the 90- deg ... but I am thnking this time to remove the shackles and lash it with light line ... with enough line free - to let me use to the reef cringle ... solving two matters in one.
