Jcorstorphine
I am due to launch my boat after a major refurbishment and as such I forced into getting a survey done for insurance purposes. In the past I have found these surveys a total waste of time as I know my boat better than a surveyor will. I also object to the usual claptrap that surveyors seem to think is important like
The forward cab has two bunks set in a V fashion with 75 mm foam mattresses in good condition. The sides of the hull are covered in a well fitted lining as is the headlining. A hatch provided for ventilation and emergency escape however it is noted that the acrylic section has some small imperfection due to the effect of sunlight.
What a load of absolute claptrap,
All I want is a simple survey which states the value and the boat is in satisfactory condition with no obvious defect to the hull which would impair her seaworthiness and has sufficient safety equipment to allow the vessel to be used within X mile of land.
Rant over
Rant over
