gregcope
I am installing an inverter (Mutilplus-II 12 3000 120-32). I want to add a breaker between the Shore power hookup/socket and the inverter. I have an existing consumer unit that has breakers for the charger/water heater and 230V socket ring. This existing cabling will be used on the output of the inverter.
I plan on input current limiting the inverter to 16A from 32A as I imagine most shore power connections are limited to this value.
As this needs only one way to break/protect between the shore power and inverter as the inverter is the only load. I was looking to fit a 32A MCB and similar RCD (30mA). This will take three ways in a DIN box. Alternatively can I fit a single 32A 30mA RCDO. This takes one way in DIN box.
Thoughts?
Thoughts?
