Inflatable- finding a leak
lezgar
15 Aug 2001
brush the inflatable with liquid soap and you will see the bubbles
longjohnsilver
30 May 2001
Yes Fairy liquid is good. Also try listening, quite often you can also feel the air escaping in your ear, if you see what I mean.
BarryH
31 Oct 2001
Surrey
"Paint" on a solution of washing up liquid and water, pump the thing up hard, when you've found the leak, mark it with a chinograph.
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
When Found . . .
Try and put a patch on from the inside of the tube (remove inflation valve to try and get access to push the patch on) as well as an external patch.
Re: When Found . . .
If soapy water shows air leaking from under valve collar, tightening it might cure it.
Worked for me on ancient avon
colvic
23 Dec 2001
Hants
Silicone grease round the threads and flap on the valve works wonders. One of the best sources for silicone grease is a plumbers merchants who stock it for use on lubricating underground drainage pipes prior to pushing together
Viking
23 Jan 2002
Ålesund, Norway.
Re: Inflatable- Older Valves
For what its worth!
I heard or read somewhere that 'brake fluid' was good on older inflatable valves, Something to do with its rubber/plastic preservering property?.
