sailorman
I have fitted and maintained many of these systems and my general opinion is this:
Add on systems are useless, and dedicated masts (mechanically)work ok when they are new but once the bearings have worn and the sail has stretch they are more effort than they are worth. This is even more of a problem with vertical battens which as the leech of the sail stretches the battens are no longer vertical and therefore take up extra space in the housing or can shatter resulting in no way of furling / unfurling sail, i have heard of many people having to burn out sail at sea just to drop the sail.
The loss of performance is also noticable as sails have little draught, zero or negative roach, and mast cannot be bent.
Far and away the best solution for you is to go single line reefing but look to spend a it on it, low friction blocks, specialist boom (i personally prefer z-spars setup over more expensive models). I would also go for a decent vang (the barton solid fibreglass one works very well on boats of this size)
Also you should look to get lazyjacks and a stack pack fitted.
You can operate from the cockpit with ease and maintain all of the performance of slab reefing.
