Dockhead
Unstick it. Knife not required.. . . I'm not sure what you're supposed to do with a furling main that's stuck, other than take a knife to the sail itself.
We are starting a group which plans a yacht share and are considering the pros and cons of various yachts. In mast furling came up and as I have not really thought about it in the past
decided that there was no better place for advice than here! I will encourage the other group members to view the comments.
We are looking for a yacht of around 10m and will be sailing in Spain. We noticed 2 Furia 33s and one had in mast which sparked debate.
In general what are the pros and cons? My only experience is watching a neighbouring yacht owner trying over days to unjam his furler and this did put me off a little.
On the other hand they do seem neat and easy to use!
I will be interested in views and experiences as these may inform our buying options.
Thanks all.
Yes, that's it.Absolutely. I mentioned earlier that I had a charter boat with a worn out baggy main that jammed and I took it to the charter company to fix, the boat was still usable. I let off the outhaul completely and used the spinnaker halyard wrapped round the mast to make fast the remaining sail. I was pi$$ed off and decided I'd get the charter company to un-jam it, so we motored to the nearest marina and they fixed it.
What happened? The wind had dropped from gusting F6 to a steady F4-5, so we wanted to let a bit more main out - a fold got caught and pulled out the slot. If I'd watched the main coming out, I'd have seen the first appearance of the fold and instead of continuing to crank it out, jamming it to the point where the furler would no longer move, I could have wound it in a bit and tried again - or only let it out on a starboard tack, which solved the problem completely. A bit like the issue I've had with battens catching in the lazyjacks, you don't continue cranking the hallyard when it starts to get stiff without investigating why.
It wasn't a difficult fix, and if I'd known then what I know now, it would never have resulted in a jam in the first place - the root cause was a very old, worn and baggy mainsail with the stiffness of spinnaker cloth. A recipe for disaster.
Jamming on the way out in this way happens when the baggiest part of the sail is coming out, so about mid-way out. You're not left with much mainsail hanging out when it jams, so it was relatively easy to tame it with the spinnaker halyard.
Jamming on the way in happens when the sail isn't wound tightly enough, so the mast fills before all the sail is in ... again, not much is left flapping about. Can usually be overcome by making the outhaul fast and continueing to furl, but it requires nice slidy stiff sailcloth.
My Selden systems have been pretty tolerant of boom position with anything from horizontal to lifted around 6 inches by the topping lift - but again with stiff, well cared for sailcloth.
Jamming or failure of the mechanism I have not yet encountered or heard of on a modern system - doesn't mean it can't happen so maintenance is essential. I would wager it's as rare as a car jamming solid on the mast track.
I have had a slight jam due to a stuck on sail number detaching and balling up on the way out, requiring a bit of force to eject it through the slot.
Just to add to that from a different angle, My project GH still had a roller reefing boom (remember that?) which a previous owner had converted to slab crudely with the leech line lead forward to a cleat on the boom and a lashing with a caribeenir for the tack. I have converted to single line in a similar way that I did on my old Eventide 30 years ago with lines lead aft. Using good blocks I have managed to keep the friction levels down, but I was surprised by how poor the the track slides were even with new slides and a clean and well lubricated track slot. The solution for that was a Tides Marine track and slides. I have not tried it all in anger yet, but it had better work as I have spent over £3.5k so far just in hardware, stackpack and running rigging!
If you have a Z Spars mast, you have no choice. They make the slot and sail space small to preserve the integrity and strength of the mast such that there is no room for (vertical) battens.At SIBS I had a conversation with Kemp Sails about in-mast furling. Their view was that modern mast furling systems were very reliable but recommended, for my use case, vectran sails and above all - in order to keep life simple - an unbattened mainsail.
Owain and Rob have a lot of experience of making in mast furling sails. The mainsail they made for my Bavaria was excellent. Furling was better than the original dacron, partly because of the stable shape and partly the finish of Vectran. I don't buy the idea that performance is an issue with 10m boats - the small loss of area is more than offset by the ability to more closely match sail area to conditions, particularly when you are in the marginal 15-20 knot wind range where modern boats that are mainsail driven start feeling as if they need a reef, so losing 25% mainsail area at a stroke. It is the rig design that is important not the size of boat.Didn’t see this thread until today. I’ve found it fascinating and appreciate all the comments and views expressed.
It’s a topic that interests me because if I ever buy another boat I will be master and crew, rolled into one and will want to control the rig and sails as simply as possible.
This is fine if you have a generous sail area.the small loss of area is more than offset by the ability to more closely match sail area to conditions, particularly when you are in the marginal 15-20 knot wind range where modern boats that are mainsail driven start feeling as if they need a reef, so losing 25% mainsail area at a stroke. It is the rig design that is important not the size of boat.
You do NOT want retrofit in-mast fueling. And don't ask me how I know.This is fine if you have a generous sail area.
Most of the boats I've owned will carry full sail up to 20kt. I think in-mast could be a compromise on these designs.
Like any design decision, you've got to look at the overall picture. In-mast is probably just fine if the boat was originally designed to have it. It may be less fine if the boat was designed for slab reefing.
So you like "tweaking" to get that extra fraction of a knot - I don't. Devil makes work for idle hands. Modern boats like my Bavaria 33 have more than enough "performance" in terms of the ability to make good passage times with minimal effort. They make no pretensions to be "performance" boats and just do not respond to the sort of tricks that you can do when you have a rig with miles of rope to pull your sails this way and that and a hull/keel/rudder design that responds to such things. I don't recognise your description of furling mains - you clearly had rubbish sails The Vectran main I had made was nothing like that, neither was the original for the first couple of years after which it did go baggy hence the change to a better sail.sorry but I disagree...
The modern fractional rig is highly tunable through a wide range of wind speeds, up to the point a reef is needed.
Put some good sails on the fractional rig; sails that don't lose their shape in stronger winds, and the boat will sail well until it's time to reef.
A furling rig, on the other hand, is not tuneable to any meaningful degree, and a partially furled mainsail is terrible on any point of sail except deep downwind. The leech is tight, with no twist. The sails frequently develop a "bubble" at the luff when partially furled. This is a high-drag shape that causes excessive heeling when sailing upwind. Tacking angles will be poor.
For me though, the biggest problem is that after a lifetime of tweaking sails to go 1/10 of a kt faster, or a degree higher.., i just couldn't live with a furling main on a boat this size; a 10m boat should be fun to sail! On, say, a huge Oyster, It's somehow more tolerable.
You are right. Add on furling had its brief moment in the sun 30 years ago but quickly died as people realised what an awful idea it was. Many of the nay sayers base their negative views on those things, but they are nothing like the systems fitted to production boats.This is fine if you have a generous sail area.
Lots of talk about electric winch / handle. If the sail has battons and lazy lines the electric winch will rip everything out if a batton catches on lazy lines.We are starting a group which plans a yacht share and are considering the pros and cons of various yachts. In mast furling came up and as I have not really thought about it in the past
Thanks all.
For a 10 m boat I would go standard.
Just wondering if electrical winches have a user controllable clutch like hand battery drillsI heard somewhere..., that on their round the world rallys, Oyster has had to do many rig repairs for damage caused by powered winches.
Not on my boat, we have Andersen electric winches, no "clutch". The winches do slow down as they are increasingly loaded. Though I never use an electric winch for furling the mainsail nor a manual winch to furl the genoa. Hand cranked - it is then easy to feel "excess friction" caused by something wrong.Just wondering if electrical winches have a user controllable clutch like hand battery drills
