Habebty
Yes, I realise that.
More blades should not shift more water, if the blades are sealing against the pump body properly.
The pump works because the ramp on the pump body reduces the volume on one side of the pump. So more water is carried forwards than backwards. Assuming there are always at least two blades in contact on both sides, adding more blades won't move any more water per rev.
It's just breaking the moving 'chambers' between impeller blades into smaller parts.
But if the sealing isn't perfect, more blades may help.
https://en.wikipedia.org/wiki/Flexible_impeller
Look at the moving diagram and imagine doubling the number of blades.
Twice as many pulses of water ever rev, but each is half the size.
Maybe there is a small effect, the blade thickness reduces the volume carried back more than it reduces the volume carries forwards?
Or maybe if the pump isn't well designed to work with the smaller number of blades?
More blades very likely to seal better?
Thanks for the wiki link, I think I am now convinced that marginal performance difference and seal wear aside, there should be no real difference in pump output.
My mate Barry will be pleased
I blame the Adnams.
