vic008
Not turning at all. Does this mean get a bigger hammer until they do?(remove Goiot hatch) Just hit it harder?
Whilst the alloy frame wouldn’t appreciate an oxy-acetylene torch, you could try a decent wattage soldering iron on the screw head.... Build a little dam of plasticine or blue tack around it and try a pool of penetrating oil to soak in?Not sure the alloy frame would appreciate me trying to heat countersunk ss screws.Personally have found oil a waste of effort unless under ideal conditions. I'm asking if the impact doesn't do it, is it a case of hitting it harder until it does (or bit shatters)
If this is the case, nothing would remove the screw intact.... The cordless ones just end up shearing the screw head off...
+1!Lustyd has it, use a cordless Impact Driver. I have found them invaluable.
With steel into aluminium I've had success pouring kettles full of water over the area. Squirt in a bit of penetrating oil and leave it a while; several kettles full over the course of a day or two. It is amazing how effective this can be!Not sure the alloy frame would appreciate me trying to heat countersunk ss screws.Personally have found oil a waste of effort unless under ideal conditions. I'm asking if the impact doesn't do it, is it a case of hitting it harder until it does (or bit shatters)
On one job alone I had to remove 154,000 stainless screws and replace.
