petem
I guess it's fortunate that he didn't hit the side full on or there may have been more casualties. Very unlucky that the poor guy was in the bow. Rather ironic that the Pershing is called 'Vision'.
15 knots is about right, probably bow up before the captain trimmed it down. Reduced visibility. Probably the only good thing you can say about the situation, because the Pershing can probably go a whole lot faster.Riviera Radio is reporting that the skipper stated he was doing 15 kts in his statement after he was arrested.
As ever the factors leading up to the impact will be the key.
My money is definitely on the latter.I wonder if the Princess realized what was happening so were trying to raise the anchor, or they were just by coincidence leaving at that moment
Pretty sure she is - the nose cone is clearly visible in one of the pics previously linked.at 92 ft , it’s probably just under the 24 M load line or what ever rule for none commercial ticket
I was thinking it might be something like that. I also suspect that part of the reason for the collision was that the Princess was moving forward during the anchor raising process and that contributed to the misjudgement by the Pershing helmsmanStatement from the skipper: he was doing 15kt instead of the authorized 5kt, he went on purpose near the other boat "to show his yacht performances" and unfortunately lost control.
that's a great definition of an aR5e then, isn't it?
What factor of his yacht performance was he showing off exactly? how to drop all glassware and scare everyone around?
Or was it to check the stabilisation of the other boat?
yachties are going to have a field day on that one...
Very tragic. Will be important for investigators to understand because so much about this is hard to explain: impact speed was high judging from pictures ; in that location anchored boats are generally clear of the "highway" for boats passing through the anchorage (that anchage is a thoroughfare, not a dead end cove/cul de sac); ime the speed limit there is usually observed; it was a cloudy night so no sunblindness; and the water was glossy smooth because literally 1-2 kts of wind (I was out, nearby, and it was very easy to see obstacles).
@lloydroberts, the "M" boat is Ma Tong, Alain Prost's new ferretti 920. Match was there a couple of days earlier.
