Identify a Water Strainer
Stemar
12 Sep 2001
Can anyone help me identify this water strainer, please? FWIW, it's on a Beta 20
The seal (O ring?) for the lid is missing - any ideas where I could get one? Is there anywhere around Southampton that would stock 100mm dia O rings?
In the interim, any reason why a bit of PTFE tape wouldn't keep me out of trouble?
Thanks in advance.
To identify an o ring measure the internal diameter and cros sectional diameter. If the o ring is a bit flat then estimate the average of the thinner and thicker dimensions.
Locative 577 might refresh an old o ring sufficiently to get a decent seal.
It will either work or it won't. Since the filter is under suction it should seal itself given half a chance but I don't know the make. I hope that you have more luck in finding a ring than I once did in Cowes of all places.
Could make one using some silicone sealant? Cover the mating surfaces with a 'grease', apply a bead of silicon, gently push lid onto strainer, allow silicon to cure then tighten lid.
Hopefully it won't leak.
Pretty close - maybe a newer version of the same thing.
Wow - who'd have thought there could be so many?
I think it's this one, which has the same label as mine.
It's an Osculati.
Now all I have to do is track down a seal!
That could be a useful "last resort"
Thanks Everyone
View attachment 136352 View attachment 136353
Thanks in advance.
You can either get the correct one at a bearing supplier but if the right diameter is not available you can either get a larger diameter O ring of the right cross section or a length of rubber cord the correct diameter and make an O ring the correct size.
The rubber cord is easily cut with a razor blade or sharp knife and then make a butt joint with superglue. It should be able to work out the diameter of the cord and size of the O ring from the cavity where it sits.
Thanks in advance.
A bearing stockist perhaps
For mail order look at people like Simply Bearings
Alternatively buy some O ring cord and make one or two
Seen on asap supplies osculati strainers looking the same. Seals are about £6-10 but the whole new strainer is from £37. Might be safer/easier to go for the whole thing and have the old one as a spare to mess with. Even give them a call as they are very good.
If you think it is an Osculati strainer, as sold by Force 4, you could go to their Southampton branch armed with a vernier caliper and measure one.
Then order an o-ring from a firm such as Simply Bearings Ltd.
Or Force 4 might be able to get one for you.
It's difficult to measure the O ring if it's missing. In practice the size isn't critical as it will stretch to fit. Get one off eBay.
Agree, if it is a water strainer "O " ring as it is not critical.
But if it is an oil seal or permanently immersed in sea water the type of material is important.
i have the same Osculati one, seems Force 4 just rebrand it to their name too.
My engine overheat alarm came on a few weeks ago, seweed got stuck in the hose to spigot area, didnt even make it into the filter
