pcatterall
I posted recently about the advisability of stopping the shaft while sailing. The consensus was that I should try to stop the rotation of the prop as I have a hydraulic TMP gear box. I want to make a simple brake ( I can stop it with my hand so not a lot of friction would be required)
I had thought that something like a laboratory retort holder might be adaptable ( these have a cork lining on the arms and a simple wing nut is used to tighten the clamp. I like something along these lines as a mistake in starting up would probably not do any damage. A simple cantilever bike brake might work with a lever to hold and release the cable. Possibly there are other similar devices which some of you may have seen which could also be adapted and I will value information on these. I know that some of you have adapted a bike disc brake but I would prefer not to fit anything to the shaft (Its 30mm by the way).
The best place to fit such a device in my boat is under a simple small sole board where there is a substantial wooden beam around 180mm above and across the shaft.
Its just some ideas for the main 'gripping/clamping’ part that I am after rather than a debate about folding props or the efficiency of the prop being locked or free.
Thanks guys.
( PS I am still having to paste my posts as there are still problems with missing key strokes )
Thanks guys.
