VicS
And presumably the aluminium shell is not in contact with the seawater.Maybe the anode is there to protect the heat exchanger shell, which seems to be made of some alloy, possibly alu? I theory there should not be any direct contact between stack/endcaps and shell due to the two rubber O-rings..
A characteristic of erosion caused by high or turbulent flow is that the eroded surfaces are left clean and shiny.I wonder about the flow erosion,
I'd think these anodes are decaying quickly because they are surrounded closely by copper alloy components. Dissimilar metals and all that stuff leading to some pretty active galvanic corrosion.
Without knowing what materials are used in the construction it is difficult to know why an anode is fitted. Perhaps the tubes are brass and liable to dezincification ??
