pandos
Today I finally opened up my liferaft which was not serviced since 2005 when it was "Surveyed & Tested, Repacked as original" it was in a cannister within which were two silver bags, sealed. one seems still vacume intact with flares, torch, batteries etc and sea sickness pills.
the other seemed fine but when I turned it over it had a small hole directly above a hole which was drilled in the outer case, I assume this was a drain hole but it seemed as if it was an after...thought.
we cut the raft out of the package to discover it was wet with a pinkish liquid, perhaps a pint in total all concentrated at the entrance to the raft, the wettest part was in the area where the supplies were kept in the form of a bag with paddles and sponges and a pump all of which were soaked and seemed to have a chrystal substance smeared upon them which had eaten through the aluminium on the oars... what could this be... I thought water pouch had burst,,, but no pouch for water... silca gel... but what source for redness and the liquid was fresh-ish water (i did not taste it..)
other than that the entire raft seemed immaculate, the fabric is very tough and with no sign of mildew delamination or any signs of ageing..
I worry about the piece of string that was used to tie the raft, It had the raft practically encircled and was tied to the grab handles on the underside.
I could not tear this string, it was strong enough to lift the raft by, if the raft had inflated I cannot see that it would not have sliced through the raft or caused it to deploy in a very odd fashion or end up with the entrance ladder tangled in it...
Is this normal practice..
will I be able to get this raft serviced and repacked or will a 16year old raft be scrapped, as being out of date.... I know I would be perfectly happy to jump into it (if the need arose)
And I would be happier in this old raft with an epirb and an AIS beacon then in a new raft without either.... (obviously new raft and both would be better)
any recommendations for reliable service centres with prices it is a Forties (b+) 6 man cannister with an RORC pack.
