James W
If you have enough clearance under the engine sump removal might be possible.
There is a gauze strainer in there with a pipe leading up to the oil pump. The difficulty might be locating the pipe in the strainer as you refit it if access is limited.
If it turns out that its the joint leaking nip all six bolts up a little ... and hope.
Its not a thin steel pressing so its not likely that the sump plate is corroded through
Was the engine exterior oily any higher if so be expecting a leak higher up when its running
Cheers Vic, i'll have to have a really good look when it's running and hopefully it's not quite dead yet. I nipped up the nearest sump bolts and there wasn't much in them, but i'll have a crack at them all next time.
At least the sump's a bit more robust than first thought and hopefully the leak will show itself in an easily rectified place.....yeah right!
I don't think the block's holed, i've had another look and I think that's just a bit of dirt.
We'll see!
