steve66
No plastic bits apart from a small sleeve Inside a rubber doughnut that was only fitted to some models. These disintegrate with normal use anyway. You can run these out of water without damage
Good. An outboard that can run on land and sea is got to be better than one that can only run in the seaNo plastic bits apart from a small sleeve Inside a rubber doughnut that was only fitted to some models. These disintegrate with normal use anyway. You can run these out of water without damage
Its imperative to drain the fuel bowls on these engines if being stored for more than a couple of weeks, fuel left in the carb for more than a couple of weeks will affect the starting performance, If you leave fuel in for longer you may find blocked jets and corrosion to the inside of the bowl. The design of the drain on these carbs is an absolute joke, and sign of salt and the fine soft brass drain screw seizes and any attempt to remove usually breaks the slotted head. At approx £50 to replace the original bowl does see a lot of engines abandonedHave a friend with a Honda and a Malta, latter is preferred as it seems to cope better with the total neglect they both get. The Honda has a mild steel fuel bowl which rusts, carb jets clog up. I would think draining the fuel bowl regularly would prevent any problems, bowls were available from Honda so replacing is possible.
