I hate my B&G Network
shortjohnsilver
22 May 2017
Refueler
13 Sep 2008
Far away from hooray henrys
I appreciate the integration of the gear .... allows true wind and all that ... but when and if I swap it all out - I would not be going for such gear. I would forego the integration to be honest ...
The question would be more along lines of "would new display fit in same space as old" ................
Refueler
13 Sep 2008
Checked and gear is the standard 110mm square design.
Its crazy ... I could replace most of the gear - Depth / Speed / Wind / Tack with NASA gear and still have change in my pocket vs the cost of just the B&G Wind !!
I've checked and NASA can be integrated to provide True / Apparent etc. etc. along with connection to MFD.
In fact I don't even need to remove the working parts of B&G ... I could slot in the NASA wind as is .... just won't look 'nice' having mixed brands !
Refueler
13 Sep 2008
The more I look at / read the manuals .... watch YT vids etc - I have feeling that when the boat had mast stepped at beginning last year for selling ... maybe the junction in the headlining wasn't connected correctly.
I remember seller saying that he had a connection to sort - but wasn't too informative about what.
People may be thinking ... hey - guy goes to buy a boat and now says that ?? The price of the boat was half the usual market price ... and the boat itself was in good condition ... the wiring crap is then acceptable !!
Fr J Hackett
26 Dec 2001
Saou
Didn't you say that your local "specialist" marine electricians had checked it out? Makes you wonder about how specialist they are.
Refueler
13 Sep 2008
What they did was to take down the masthead unit and check taht - which they found nothing wrong with.
I then checked the display for function ...
Due to time constraints - they could not check all and was left at that for possible later return to if I could not complete rest ... the cable was assumed OK - because there was direction coming through ...
No matter what I do - wind speed just does not register ... the masthead unit was taken down .. serviced .. checked by yard guys (they repair such gear !) .. I get direction - but speed just does not show ..
As far as they could tell - data was being sent .. but not displayed .. display passes all tests / menu functions ...
Fr J Hackett
26 Dec 2001
Saou
He said the MHU had been checked not the boat wiring ;)
TBH the first place I would look before going up the mast was the wiring connections especially the through deck ones which would eliminate either the masthead unit and wiring or the display. After that if there is a problem between the junction and masthead then check the unit.
rogerthebodger
3 Nov 2001
My Simrad MHU has a 3 phase potentiometer as described and the wind speed pluses is generated by a magnet passing a Hall effect sensor as used in water speed pulses
My smrad looks similar to the B&G and has the same 6 pin plug
Refueler
13 Sep 2008
Most likely not only one with such ... but as we know each brand likes to tweak to prevent cross branding ....
