john
Maybe I should get out a bit more.....
https://lh6.googleusercontent.com/-...oXNOv4/w469-h376/A+machine+making+a+chain.gif
This is French chainThe moderators should delete chain letters......
N
Reminds me of those old interlude on the tv
It's staggering to think of the forces involved - if you were to hold some of that rod in a huge vice and smack it wiith a sledgehammer, you'd need a few hits to start it bending, and that machine bends it perfectly like it's plasticine!
The wire used for chain making is extremely ductile and quite low strength. If you try the weld test shown on my website at the bottom of this page http://coxengineering.sharepoint.com/Pages/Chaindefinitions.aspx you will find that 8 mm chain can be bent easily using a 10 inch adjustable spanner. Chain up to 12 mm is made using these machines, which would clearly require a bit more force, but nowhere near as much as you might think.
You are worrying me now, I'll never sleep soundly at anchor again.![]()
The ful version. Welding around 3:40 in to it.I too found it addictive! But how is the chain welded? This loop only shows the links being formed, not welded.
http://www.youtube.com/watch?v=jmzLmKmmMwc
Some years ago, at the Black Country Museum, I watched a blacksmith making chain by hand, using only a hammer and tongs IIRC. He worked in a very rhythmic way. Not as fast as this machine, but surprisingly quick all the same.
Shaping the link and welding was all one operation. Looked good quality chain.
Brilliant! I can see why it is made in China - H&S precautions looked to be pretty much non-existent; no safety guards or anything. But an amazing bit of automated production.
I find it intriguing that when the weld current is applied it chooses to form an arc at the joint rather than go around the wire and short out the supply!
