paul salliss
What the pros and cons of these when compared to standard electric versions that are normally supplied by main stream builders of boats please?
Well, for that purpose alone, you might as well have an hydraulic pump on both engines.if I was speccing an ideal hyd thruster system, I'd want a back up pump powered by a gennie too just in case of an engine failure which would be the one situation in which you'd really need the thrusters
In fact the Horizons do seem to have a hyd pump on both engines (both gearboxes in fact) but I was told that one was dedicated to the stern thruster and one to the bow thruster so, in the event of an engine failure, one thruster would be AWOL. Thats why I suggested that an additional pump on a gennie plus a valve to feed oil to either circuit would be a plusWell, for that purpose alone, you might as well have an hydraulic pump on both engines.
TrueThough if you would have also hyd STAR stabs, the genset driven (either via genset PTO or electric motor) hyd pump is a must anyway.
The broker is trying to sell boats and he's very proud of the fact that all Horizons are fitted with hyd thrusters and he likes to show offRegardless, I strongly disagree with the refueling method of that folk, fwiw.
Mmm... never heard of such setup.I was told that one was dedicated to the stern thruster and one to the bow thruster so, in the event of an engine failure, one thruster would be AWOL.
LOL, can't argue with that!The broker is trying to sell boats and he's very proud of the fact that all Horizons are fitted with hyd thrusters and he likes to show off
Well there were definitely 2 pumps on the 64ft Horizon I looked at recently, flanged to each gearbox and when I asked the broker, he said each was dedicated to bow and stern thruster independently. To divert the flow of both pumps to one thruster or cross over the flow to the other thruster would require additional pipework, valves and some kind of proportional control system, all doable of course but at a cost. IMHO, it is unusual for a builder to fit hyd thrusters to a boat of this size as standard anyway but to then expect the builder to fit a crossover system as standard as well is probably an expense too far unless a buyer is willing to spec it as a cost option. Don't forget most production 64 footers are only fitted with an electric bow thruster as standard with an electric stern thruster as an option so for a builder to fit both bow and stern hydraulically powered thrusters as standard is already a step further, even if they are independentMmm... never heard of such setup.
Technically feasible I suppose, but imho pointless vs. a single circuit arrangement.
I accept that with the engine(s) idling, one pump could be not man enough to run both thrusters together at their max power, BUT it's still better to have the choice of which thruster to use alone at its max power (or both together at lower power), regardless of which PTO pump is working, rather than be restricted to either bow or stern depending on which PTO pump/engine is spinning. Or am I missing something?
Well, I might be missing some obvious bits here, and I'll gladly stand corrected if anyone knows better.To divert the flow of both pumps to one thruster or cross over the flow to the other thruster would require additional pipework, valves and some kind of proportional control system, all doable of course but at a cost.
I wait for jfm to explain but AFAIK, hydraulic motors cannot operate in series or parallel from the same circuit, if that is what you are suggesting, because the oil exiting the motor (the return oil) is at a much lower pressure than the feed oil, so each hydraulic motor has to have it's own feed and return pipes. Yes it is perfectly possible to have 2 hyd pumps feeding 2 or more hyd motors such that you could feed 100% of the oil to one motor or a proportion of the oil to more than one motor but as I said that would require an electrically operated valve system to distribute the oil flow to each hyd motor feed pipe and an electronic system to control the operation of those valves in response to inputs from the operator. It becomes more complex if the hyd motors have different pressure/flow requirements and then if the functions driven by the motors require proportional operation and prioritising one over the other, the system may need some kind of programmable control system. All this is bog standard hydraulic stuff but there is a cost to it as I saidWell, I might be missing some obvious bits here, and I'll gladly stand corrected if anyone knows better.
But in principle, I see no reason why the two pumps couldn't just feed (in parallel) a single hydraulic circuit driving both thrusters (and/or anything else, like winches or stabs).
IIRC, jfm has hyd thrusters and double PTO pumps on M2. Maybe he can tell us how they are configured?
Yep, exactly what I thought to be the logic on every boat I've seen with hyd PTO(s) plus separate pump for STAR usage.The two pto's and the electric pump are all plumbed in parallel to the manifold off which the users take their oil via solenoid valves
Well yes thats what I was trying to describe but there is a cost to that and I presume that Fairline didn't include hyd bow and stern thrusters as standard on the Sq78 (correct me if I'm wrong there) and almost certainly not on the Sq65 which would be equivalent to the 64ft Horizon I saw. All I was trying to say was that 2 hyd thrusters fitted as standard on a 64 footer, even if they are independent circuits, is better than1 or 2 electric thrusters as fitted to most other boats as standard. I'm sure you could have an integrated system on the Horizon, just as you specified on Match, but I guess you'll pay extra for itThe two pto's and the electric pump are all plumbed in parallel to the one manifold off which the users take their oil via solenoid valves, proportional on a sexy system
Absolutely which is why I said its all bog standard hydraulics stuffNothing more elaborate than this is needed. Same for a jcb that has perhaps 10 rams all drawing off the same manifold
Yup thats simple hydraulic prioritisation which is common on many hydraulically driven machines and has been around for years but as I said, it's the kind of sophistication which costs a bit more money and you probably wouldn't expect as standard on a boatHaving said all that you can then tweak it. On my boat this is done via the control electronics. When I demand thrusters the electronics don't allow the stabs valves to operate. The logic is that thrusters are more important, which makes perfect sense. If you were docking boat on one engine and needed max thruster power you wouldn't want to waste. Power on stabs. But that's all achieved via control softwAre not plumbing
Mmm... I struggle to see how a manifold could add any meaningful costs to a setup with two PTO hyd pumps and two hyd thrusters.All I was trying to say was that 2 hyd thrusters fitted as standard on a 64 footer, even if they are independent circuits, is better than1 or 2 electric thrusters as fitted to most other boats as standard. I'm sure you could have an integrated system on the Horizon, just as you specified on Match, but I guess you'll pay extra for it
