Hydraulic steering on OB drifting one way
simonfraser
13 Mar 2004
Seems like it is slipping, but only one way
steers ok but wheel not returning to neutral when straight ahead
i‘ve had it off the grooved pin and reset it several times
running low on oil, odd, or is the hub failing ?
tnx
PCUK
29 Jun 2005
Westleigh, Nr Tiverton, Devon.
Hydraulic steering always slips, there is no way to keep the wheel centred constantly. The slipping is due to prop walk. I assume there are no non return valves on the system. Fitting them will stop the side slip.
Keith-i
4 Jul 2012
Jersey
As stated, depending on size of engine there’ll be some prop walk or torque steer effect. My DF200 does this on my rib and you are constantly making small corrections on long trips.
simonfraser
13 Mar 2004
sure, prop walk i figured
but hydraulic slip is different ? if i make large course corrections the helm and the OB get out of synch
westernman
23 Sep 2008
Costa Brava
www.devalk.nl
May be the the seal on one side of the hydraulic ram is weeping?
If you are running low on oil it is definitely leaking somewhere. Probably one of the seals on the ram.
simonfraser
13 Mar 2004
Yeh possible, nothing obvious, rams in plain sight
going to top it up and check fluid loss
but, should the helm go out of sync with the motor position, can go out of sync by a good 90’ after a turn during a straight run
westernman
23 Sep 2008
Costa Brava
www.devalk.nl
Something definitely wrong.
Just check you don't have a valve to disable the hydraulic system altogether. May be that is partially open. I have one on my boat. Then when turning the wheel absolutely nothing happens. This is to allow an emergency tiller to be used. However, in this case no hydraulic oil is lost.
I also use this short circuit valve it to stop the waves when moored from trying to move the rudder continuously against hydraulic pressure.
I never managed to completely stop the seals from leaking at least a little bit - even after a complete rebuild of the ram with new seals.
Rappey
13 Dec 2019
Did it use to self centre? Is it powered or mechanical? What is the max hp of your steering system and hp of the engine?
Do you have an autopilot?
I would think the non return system is built in to most helms, without it the outboard would always be fighting you due to prop walk which surely would defeat the object of hydraulic steering?
If your turn the helm but the engine doesnt quite feel like its turning, thats usually low fluid/ air in system.
PaulRainbow
16 May 2016
Suffolk
A little creep is not uncommon (depending on the system) but 90 deg sounds too much.
PCUK
29 Jun 2005
Some systems don't have nr valves to allow for “feel” in the wheel when steering so still quite likely the problem.
QBhoy
11 Mar 2016
That’s not normal at all, I’d say. Must have low oil, need refilled or bled. All three possibly. Not sure about the “returning to neutral” thing though. It won’t straighten the wheel itself from a turn, like a car will. If that was assumed. Perhaps it wasn’t. Thought I’d mention anyway
simonfraser
13 Mar 2004
did not suggest an automatic return to straight ahead like a car, perhaps if i had twin OB's with a bit of toe in or out ;)
OB getting out of sync with the wheel steering, will be topping it up first of all
