Hurth Gearbox fluid
Fascadale
15 Jan 2007
One end of the A1
I have been told my Hurth Gearbox should be filled with A.T.F.oil which I presume is "automatic transmission fluid" oil.
Are all ATF oils the same or should I be looking for something more particular?
Will the stuff from Halfords do?
Salty John
6 Sep 2004
UK
My Hurth box took ATF type A. Most ATF's meet the requirements of type A, just check the small print on the bottle.
Hoolie
3 Mar 2005
Hants/Lozère
... ... except it doesn't mention type A on my 1 litre container of Castrol TQF DIII. I had the same problem and found (Google!) that this is a modern equivalent to type A. ps don't use type F it will ruin the clutches!
Phoenix of Hamble
28 Aug 2003
East Coast
... and if you ruin the clutch plate, and its an MD22 or Perkins Prima its attached to, you're in for a very very unpleasant surprise at the cost for a replacement!!!!
chrisgee
15 Feb 2005
Bath
Sent you a private message re possible problem with a 411 I am looking to buy.
