PatrickB02
Hi Patrick Have you had any issues with the engine? how do you get at the stern gear through the port cockpit locker??
No, touch wood, the engine has been fine so far. It's a 1GM10, and I have not had to do much more than routine annual maintenance.
I changed the exhaust elbow for one of the stainless steel ones from the USA, as many other people have. I had a drip from the water pump, so had to strip that down and replace the seals; the drips had also rusted the oil pipe so I had to replace that as well - again, these are both pretty much standard for the 1GM10 and nothing particularly difficult for DIY.
The stern gear is accessed from the quarter berth, which is nominally (ahem!) a double berth and extends under the cockpit sole. Lifting the cushions and hatches gives pretty good access to the back of the engine, gearbox, shaft and stuffing box.
