Humber charts
ALPHORA
25 Apr 2005
Scarborough
ABP publish charts for the Humber, updated every few weeks. B Cooke in Hull, or Kildale Marine at Hull marina stock them I believe. The channels wander so an up to date chart is advisable, especially if you are heading out of the main channels
Bellamica
9 Apr 2011
Humber Mud
what do I need
at the moment I have reeds and the imray tidal havens
what else do I need given that I am planning to go as far inland as the keels will allow - I will be dropping the mast
Dylan
If you are new to the river, I suggest, once west of the bridge that you stay to the edge of the buoyed channel. The charts are updated monthly by ABP, nothing stays the same for long except the navigable channel, the buoys (30' boats) are moved regularly. Shipping is busy up river at the start of flood and down river with the ebb but is restricted to the channel.
The Coast Guard will connect you to Humber Rescue if you run aground, make the call quick if you do. Humber Rescue are very slick and if called in time can extricate most boats from the mud, if not they will help you secure your boat take you ashore then return you to your craft on the next tide all for free but please make a sizeable contribution if that should occur. You need a strong and reliable engine, as tides can be in excess of five knots so if you don't make refuge before the ebb you probably wont, the mud is very very very sticky make sure you have plenty of water gas you may need a strong cupper......may see you at South Ferriby (good pub and food right by the lock gates, lock keepers like 24 hours notice if out of office hours)...Fair winds
dylanwinter
28 Mar 2005
Buckingham
www.keepturningleft.co.uk
triple keel
the slug has triple keels
are there many steep mud banks that are going to get me
it does sit astonishingly upright given the chance
so going aground generally does not bother me that much
Dylan
MrCramp
2 Sep 2006
East Midlands
You don't want to go aground/on the mud with the tides running as they do. The Humber is unlike anything you will have come acroos on your travels so far.
You do need to buy both the charts, the Upper Humber and the Lower Humber, and then you need to update them with the weekly notices issued by ABP.
You might cruise the Humber once, you will not return!!
dylanwinter
28 Mar 2005
Buckingham
I won't risk it then
now you have frightened me off
I have decied that I will skip the Humber and go on up to the Tyne
Dylan
AntarcticPilot
4 May 2007
Cambridge, UK
www.cooperandyau.co.uk
Agree - and the channel edges are STEEP so it is very easy to go aground and roll.
Beadle
20 Aug 2007
Rural Nth Yorks - 2 miles from bus stop, 8 miles f
Dylan
Don't let the doomsayers put you off.
The lower river from Spurn to Hull is busy but well marked and easy work. make sure you listen to CH12 Humber radio and you will get warning of shipping movements
Enter the river and if it isnt low water or very near drop the hook off the pier inside the point and wait for LW. Keep to the North of the main channel until near Paull and hen take the marked channel to the north bank rejoining the main channel upstream of Paull.
You should be in nice tome to drop into Hull Marina. Go to Kildale Marine and buy the latest upper river chart.
Leave Hull Marina (on the next tide) and follow the line shown by the BWB chart. Be prepared to drop out of the channel if there is any shipping approching (keep a good look out astern - they sneak up on you). Look at the chart before moving out of the channel - it may be you have to go to port to have enough water to clear the channel.
If you are taking the River Ouse pass close to Blacktoft Jetty.
The channel up the Ouse is fairly straightforward for a small boat. Keep to the outside of bends where there is the best water. Proably best to drop into Goole. Call sea lock on 12 They will give you directions to the 2 "marinas" just off the Aire and Calder. They will also open the bridge for you but you may have to wait a bit.
Go for it!
dylanwinter
28 Mar 2005
Buckingham
excellent instructions but....
Dylan
Go for it!
plan ning to come through the baqck door after the inland route through Lincoln
even if I ge to Boston on tuesday night planning to leave the boat in boston for a week and another week looking at Lincoln
D
Mike Gowland
12 Nov 2011
Sailing the Humber
The River Humber remains one of the most challangeable water ways in GB but in say that the challangeable is well worth it and remains one of the best training grounds there is, after all Ellan McArthur trained here. Provided you stick to the main channels you'll be fine and on a rising tide most areas are navigable.
I have sailed here for the last 15 years with no mishaps.
Mike Gowland
KHYC Commodore
alexrunic
5 Dec 2007
Humber
yet more negative comments about one of the most interesting and beautiful rives in the uk. When was the last time any of you sailed on the Humber?
As well as the two ABP charts i would recommend the boating association charts for the Trent and the Ouse. there are many sholes on both rivers. It might be worth checking with the British Waterways in case of any lock closures.
http://www.theboatingassociation.co.uk/Merchandise.html
MrCramp
2 Sep 2006
East Midlands
Do you know where you are going to leave your boat in Boston? It is 4 years since I did my regular run up through there to the Trent but all the moorings above the Grand Sluice had to be vacated about this time of the years as the water level was lowered to allow for water management in case of floods.
I think there is a lock now opened into another waterway, but I am not sure.
If you do have some mooring arrangement then Boston is an interesting place to visit. The Weatherspoons pub does decent meals at a good price.
Lakesailor
15 Feb 2005
Near Here
If you miss it out your whole concept will be flwaed. May as wel go home now.
Just travel on the flood, then you won't get stuck.
Or travel out of the channel, away from the edges. (Best get a hovercraft)
dylanwinter
28 Mar 2005
Buckingham
ktl flawed concept
that is probably true - missing the Humber would wreck the whole thing
but as other posters have said above -- I am going to die on the Humber because it is such a dangerous place and only the very, very skilled or fool-hardy should ever contemplate going there
as I am the latter.... rather than the former
I might well give it a go
D
