Hull waterline stain removal
38mess
9 Apr 2019
All over the shop
I'm going to try Harpic, thanks for the tip. I used to use oxalic acid which is ok if used in warm water, then I tried 'Grunt' which is better in my opinion, just leave it do it's magic then rinse off, but expensive. Going to get some Harpic.
pandos
15 Oct 2004
Ireland, (Crosshaven)
Any views on the best way/ratio to make it sticky? I tried wallpaper paste last year and it went lumpy straight away. Thanks!
I use a few teaspoons in warm water until no more will dissolve... Then top up with aldi washing-up liquid... Works a treat... I use peanut butter or nutella jars...
When the rust is go one I wash it all over with a bucket of water and a sponge and then hose off...
Denek
12 Jan 2013
Thurleigh bedfordshire
comparison photos. One side took about an hour and I did use a scotchbrite type sponge to give it a rub. Not yet polished but it’s come up really well and at £1 a bottle from B&M what’s not to like.
any recommends for polish? Can’t remember what I used last year but it was not cheap. I think because it had the word marine in the name.
Poignard
23 Jul 2005
London and Brittany
I would rather have a dirty boat than eat peanut butter or Nutella ?
Seriously though, I just dissolve oxalic acid in warm water, as you do, but I had never thought about adding washing-up liquid. But I will try it next time. What difference do you think it makes?
rotrax
17 Dec 2010
South Oxon, Littlehampton and Wellington, NZ.
It allows it to 'stick' and not run off a vertical or sloping surface.
I recently mixed 50/50 oxalic acid crystals and warm water and added to the same amount of fairy liquid. It was fairly thin, but thickened up nicely after a few days.
Works great, stays put and when washed off the detergent seems to help soap it away.
Well pleased - a kilo of crystals cost half of what a tin of Y10 costs.
pandos
15 Oct 2004
Children can be used for dealing with nutella... peanut butter best spread on a hot toasted bagel with coffee for breakfast...
The washing up liquid makes it thicker and suddsy and easy to see on the fiberglass....(Put on with paint brush) when washing with the sponge so it cleans stuff that the OA would not take away... Being suddsy it helps the water to hold the grime that has been lifted off....
I got this recipe from a guy based in France and have given jars to people who routinely used y10.. many comeback for the recipe...
C08
8 Feb 2013
I find Starbrite Rust Stain Remover spray works better than Y10 or Oxalic Acid in any of the application modes. As previously noted you have to do the whole hull as the contrast to uncleaned areas is enormous.
KINGFISHER 8
21 Mar 2007
South of France.
I found this recipe on the Ribnet forum for rust stain removal
1 litre of luke warm water
200g Oxalic acid powder (ebay)
50mls car wash detergent (any mild liquid detergent)
Wallpaper paste powder (to required consistency)
Add the acid to the water. Slowly add paste powder until mix starts to gel. Go short and leave it a while - it thickens for a few minutes. Then add detergent. Brush on, leave 10-15 mins and pressure wash off. Avoid galvanised metals, chrome etc. Wear PPE. Safe on stainless steel.
But oxalic acid is not as soluble as this suggests. Some will crystallise out as it cools I am sure Therefore reduce it to between 100g and 150 g / litre
....... Or just go to the chandler and buy something made for the job! ... ;)
Poignard
23 Jul 2005
London and Brittany
Thanks I will certainly try it.
TSB240
17 Feb 2010
Do you have a badly oxidised surface on your GRP? A grey( fine ) scotch brite pad as used by car body shops will remove this. It is less scratchy than using fine wet or dry and requires less work with compounding and polish to give an as new gelcoat finish.
peteK
4 May 2009
Wirral
It might work well but at £28 can't see many people using it.
