Portofino
On what do you base that statement? It's just your hunch PF; it isn't actually true. If your clinker or smooth dinghies are is sitting at anchor and then a wave comes, the last thing you want is grip on the sea, because that will make you roll in line with the wave. You'd rather have slippy. In any case, the drag/grip effect of all the chines/rails at these water velocities is immeasurable except with instrumentation
As for the rest, you are lost in the fantasy world where you think that a deep vee hull needs lift strips for lift, because in your world a sloping surface doesn't provide enough lift. That defies physics, though I agree it is an oft-quoted concept. If it were true the addition of spray rails to a V hull would cause the boat to sit higher in the water at rest, which obviously is not what happens.
The function of a rail is to shed spray, which is critical to (a) drag in the context of fast boat performance, and (b) dryness on less performance-oriented boats.
Here you can see that the flat chines resist roll or multiple clinks on a clinker .
Plus other stuff about deep V,s static stabilty ---
it's blatantly obvious a round smooth hull section will roll more than a hull with any flat bits to resist
Please read post # 74 and MapishM responce then reconcile it with my point about "hard chines " or wider then normal chines --- more flat bits to resist .
Ray Hunts team and my self be sharing the same fantasy JFM
http://huntyachts.com/mythbusters-the-real-truths-about-the-deep-v-hull-2/
Here it explains the difference between a spray rail and a lifting stake --- some how I think you and MapishM do not realise there's a difference ,or accept lifting strakes exsist or have any function ? I,am talking extra wide ones to look out for that do not peater out .
Remember it's what you can tell looking at the hull form with Mk 1 eyeball ---before diciding of course for a test drive .
http://www.aeromarineresearch.com/tbdp6/strakes_and_sprayrails.html
What's wrong with looking for a few subtle "Hunt " Q,s ------------ it's a boat forum and the hull staring you in the face
(if it's not skirted @ a show
