Hull inlets etc..
stownsend
15 Sep 2006
South Wales
Hi
What hull inlets / seacocks do you reckon are needed on a small 22 foot cabin cruiser. I've got a volvo penta 250 set (AQ151 and 290 Leg) so the engine is cooled via the leg so one's not needed there. I would assume one for the heads water inlet but apart from that I'm lost.
If this is the case I've got quite a few existing ones to remove and glass over the existing holes !
Cheers
Stu
volvopaul
1 Apr 2007
midlands
hotmail.co.uk
Most sea toilets req minium 1/2 inch inlet but 3/4 may be better as there is no filter req, 1 1/2 out let for waste is about right, space them as far apart as poss, as sometimes if there too close you draw in what you have just pumped out, not a pretty sight after a heavy night!
Its_Only_Money
11 Aug 2004
Leicester - boat on Hamble
My Fairline Sprint is that size with a leg inlet for the engine cooling water, in addition it has below waterline seacocks for the head inlet and outlet and above waterline through hull fittings (no seacocks) for Galley sink drain, heads sink drain, two cockpit drains and bilge pump outlet.
Hope this helps!
