jdc
My thoughts also
Certainly doesn't seem to relate with a "slippery yacht", perhaps good for a motorboat/ fishing boat?
You're right there! I did it for a long keel cruising yacht (I did say it was a starting point, so I chose my boat!).
But I tried a sanity check nonetheless. At the bottom end my old Sadler 29 (which is 28' LOA actually) had 20P, and my current R42 boat has 50HP. Ex Solent Boy's R44 is over powered I think and probably only 'needs' the 65HP engine, but isn't way adrift. A big Bav has 110 HP for 55' and the Oyster 62 has 185 HP so the 'scatter' is both sides of my graph.
The main thing I wanted to convey is that 'rules' such as so much per ton or so much per foot are illogical, one has first to work out whether (and why) it should be directly proportional at all: why not a square law, or an exponential, or a log, or a factorial or some such... It's simply ignorant to assume direct proportionality; one needs to do some dimensional analysis. The separate considerations of driving against a strong wind and driving the hull through the water are not scale invariant.
