how upright does an OB need to be to drain cooling water ?
simonfraser
13 Mar 2004
noticed yesterday in the yard that there are a fair number of OBs tilted on the back of boats on a trailer
some tipped over by 45'
when does the water drain out fully ?
-5C next few nights, yesterday my OB in the yardwas at 0C 1pm ...
spannerman
30 Nov 2002
Will only drain out fully when vertical, if tilted there will be some water in the bottom of the gearbox where the prop shaft carrier meets the bottom of the exhaust downpipe.
QBhoy
11 Mar 2016
Likely find that they have drained and expelled any water before being tilted to an up position. Not to say that they won’t have rain water sitting in the exhaust cavity though. I always tilt mine down after she comes out for storage then lift a little afterwards in case the yard need to move the boat around over winter. Put a prop bag and full cover on it additionally too. Do the same with my outdrive boat too.
spannerman
30 Nov 2002
They don’t drain straight away, you have an impellor above which is a pipe going up to the engine block. Thewater fills up the block and when it gets to the top it then overflows into the exhaust manifold cooling jacket and the free falls out of the leg. When you turn the engine off this drains down but the water in the pipe above the pump slowly leaks out past the impellor, some drain quicker than others.
