How to wire batteries? - Alternate method?
Tintin
21 Mar 2009
Kernow
I have always assumed that the correct way to wire up the batteries (aux and engine bank with a VSR/ VSS ) would be something like this.....
And then reading a book on boat electrics (Boat owners illustrated electrical handbook, Charlie Wing), I came across this alternate method which seems to ensure that at no time can a load be unswitched from the alternator, thus protecting it.
I am tempted by this as the basic schematic - any thoughts or issues anyone can see?
thanks
CR
BabaYaga
19 Dec 2008
Sweden
My batteries are also wired as in no 2, but consider the position of the fuses.
In the sketch, both the the starter wire and the alternator wire are unprotected.
20 Feb 2014
thanks
CR
In addition there are preferred methods of connecting batteries together in banks, I found this very informative, hope others do to.
http://www.smartgauge.co.uk/batt_con.html
TradewindSailor
26 Jan 2007
New Zealand
I also have a system close to 2. With a large house bank (750 Ahr) it is the best way. Obviously the cables should be fused close to the battery.
The first arrangement is typical of standard Yanmar arrangements ...... which to my mind is shortsighted : the alternator is usually internally regulated as standard, so it relies on local voltage to regulate the charge. The additional connection at the started is likely to introduce an additional voltage drop, especially if it get corroded ..... and hence none of the batteries get a good charge. At least with the second arrangement the house bank ..... usually the largest and most expensive bank ... is prioritised.
