Daydream believer
I have a pretty standard battery set up on my boat.
2 No. 2 year old 100 amp AGM batteries as domestic. 1 No 35 amp Red Flash battery as a starter. they are connected by a VCR.( forget the make- begings with "V..." & wired as per instruction) The domestics have a single isolator. Te red flash has the same. there is an emergency isolator that would ling all 3 batteries if required.
I have a NASA battery monitor to the domestics only.
I have a Dolphin triple stage charger connected to both domestic & starter batteries. It kicks off at 14.4 volts ( as shown on the NASA) then drops to 13.3 V
The problem is this
I charge the batteries up & they take something like 4.5 amps for some hours. Then this charge drop down to virtually nothing over a 24 hour period. The NASA shows batteries full at 13.3 V.
I turn off shore power & the NASA records a level after a day or two of 12.7 V even though I have the isolators OFF. If I disconnect +ve on all 3 batteries & measure voltage across each one they all read the same. So the starter has charged as it should. Left disconnected they stay at 13V
I suspect that I either have a duff battery drawing the others down, or I have a leak that is running past the isolators- ie can it run back up the battery charger.
So my question is - How do i use the multimeter to check if there is a current discharge on any of the batteries. Where do I put the mutimeter wires & what do I put them to. Do I put them in the circuit or across the circuit somewhere. what do I set the meter to? amps volts ?
I have no idea so guidance would be appreciated please
The problem is this
