Greenheart
My lightweight launching trolley consists of a wooden hull-support braced with a steel bar, and a 40mm aluminium tube from the timber to the bow, including a shallow 'V' to lift the nose. The front 'pulling' end of the trolley is the same 40mm-section cross-bar.
In theory it looks like child's play to bolt-on a jockey-wheel...but all the clamps I've seen, assume attachment will be to a flat surface, such as box-section trailers use.
What I need is the standard, circular clamp for the upright of the jockey-wheel column, mated to another circular clamp for attachment to the trolley's horizontal bar.
Obviously it'll need enormous grip - hard to achieve - because every movement of the trolley on rough surfaces will be pushing the wheel backwards from vertical.
I'll need a jockey wheel because hauling-out will require use of a rope purchase, and the nose will otherwise drag along the slipway.
Any ideas how I can secure the jockey-wheel pillar to the round 40mm cross-bar? Thanks.
