fliti
We are setting out across the Atlantic in January and our perfectly healthy sail wardrobe of furling genoa and in mast furling main plus cruising chute should do the job as long as nothing untoward happens. Of course, we need to anticipate just that so having an extra sail aboard in case one suffers major damage en route makes sense. On the other hand, it's hard to justify the expense of a new sail which will most likely spend its life in the locker. Enter my sis and brother in law who have kindly contributed their old genoa. Rigged properly, this should fill any gap that arises. However, it is a lot smaller than the existing genoa-about 60% compared to 155% and much shorter in the luff-about 12 metres compared to a forestay of 17.5m . So, the question is, what would be the best way to rig, if we had to?
We could run it up tight to the furler drum, keeping it low to the deck and either run a line from the head several metres up to enable the swivel to stay at its usual height close to the top of the foil or only raise the swivel to about 2/3 of the way up the foil, with the head lashed to the swivel as usual. We could also fly it higher, with a line down to the drum, bracing it to the foil with extra ties in case it was pulled out of the groove, again with a line up to the swivel at the top or with the swivel well short of the usual position.
Can anyone advise, please?
