NealB
I did not say whack the pulley - I said whack the pulley flange. It is a substantial piece of steel pressed tightly onto a 5/8 ish shaft. You wont break that with a length of hardwood and a hammer! If it wont shift any other way you are kinda captured, are you not?
If you do whack it and it does come off, if it is leaking as you say, the face seal is shot or the bearings are shot, so you will need a new one.
You can get the pulley flange pressed off to change the bearings and seal. A guy I know used a service kit for an East European light truck - Avia? - and used the face seal bits suitably modified for his particular water pump. The bearings were off the shelf.
Montego used a Perkins derived unit, not the old 2.2 BMC pushrod donk.
Dont be shy, tickling it wont work!
OK .... thanks, yet again!
Now ..... please excuse my deep, profound, ignorance of basic engineering terminology (sadly, we didn't cover flanges in my accountancy studies), but I think you mean that I need to 'whack' the pulley close to its centre (rather than its circumference)?
That is, of course, certainly what I would try to do, but I think getting some sort of relatively non-damaging drift near the centre will be extremely challenging, as the pulley sits quite close to the block, so space is very restricted. I'll take a closer look tomorrow.
The whole point of trying to remove the pump is so that the seals (water and oil), and the bearings can be replaced. They seem to be available from several sources.
Right, I need an early night to visualise tomorrow's challenges!
