coopec
N/A
I have 900mm stanchions which must be bolted to a cored deck. (Where the stanchions are located there is ply pad insert)
In an attempt to avoid leaks I had planned to insert a neoprene gasket between the stanchion base and deck with butyl around the bolt holes.
(The mounting bolts will be torqued up quite firmly)
Will this avoid leaks? Is there a better method?
Advice will be appreciated.
