gordontytler
I suspect there is an air leak somewhere in the pipework between my sea cock and the raw water pump and I hope to fix this tomorrow.
After the engine has been off for a while I needed to run at high revs to prime the pump again. This was happening each time I went through a lock. One time I forgot and I think now need a new impeller. It no longer primes.
There are about 8 places where rubber pipe connects to the filter, the grear box and some sections of copper tubing.
Is there a quick way to work out where the air is getting in?
Is it a good idea to use plumber's PVA tape on the connections?
It's a Mercruiser/BMW 636.
thanks
thanks
