NormanS
Jonathan, while greatly respecting your knowledge and expertise on these matters, as you know we see some aspects rather differently. If I had a Bav 45, there is absolutely no way that I would be using 8mm chain for an anchor rode. I am still old fashioned enough to believe in the benefits of catenary, and accept that that requires the use of suitable chain for the purpose.A 45' AWB with no added windage over the standard yacht, say a Bav 45 with 30m of 8mm chain deployed at a 5:1 scope and enjoying around 17 knots of wind has a tension of about 68kgs in the rode and the very last link, at the anchor shackle will be 'just' lifted of the seabed - this is the sort of tension a reasonable fit individual mightl hold - at least temporarily. This is a simple all chain rode, no snubber. I have measured the tension of such a rode, no snubber, at 17 knots and I have measured the tension. necessary to lift the last link off the seabed. You tell me that you experience many 10s of knots of wind in anchorages in the Western Isles - I suspect you might agree that 68kgs of tension is 'light' - but maybe you will want to indicate that this is heavy - if so please define 300kgs of tension, the maximum I measured was 650kg (at 35 knots) - and I chickened out at that point.
I do accept that it is all relative., heavy, light etc etc - Zoidberg, Post 76 did make the observation that terminology might lead to some confusion, maybe a case in point.
Jonathan
I accept that some boats, particularly light weight boats where every gram of weight carried is a handicap, find it necessary to compromise, for those of us with more traditional craft, the actual difference between light and heavy chain is of little consequence.
By all means carry on with your crusade for light weight high tech chain and the resultant requirement for cat's cradles of snubbers strewn around decks, for your light weight and multihull brethren, but please remember that such methods are not appropriate for all boats. Our own boat, for example, carries three tons of ballast around, so a few extra kilos of chain is neither here nor there.
A happy New Year to you and yours, when it comes, which won't be long in your case. ???
