Greenheart
I always fly, and I reckon LJs are supplied. The girls in crew-uniform always seems to be showing theirs off. Not sure why though - hard to think how it would help after a crash.
I always fly, and I reckon LJs are supplied. The girls in crew-uniform always seems to be showing theirs off. Not sure why though - hard to think how it would help after a crash.![]()
You see the point though surely. Most wear a pfd in a dinghy, few in a ferry. Where the cut off is depends on so many factors. Whether you wear it or not should be your choice. Whether I do should not.
Maybe wearing the supplied lifejackets should be compulsory once the plane gets over water? 'only effective when worn'.
OOps sorry I have read that 3 times and still have no idea what you meant!![]()
My previous posting appeared twice, exactly the same. #61 and #62. I have now realised, by the way, that the "Posts" count at the top right is the total the author has made to date, not at the time of posting.
Because that is the danger of "no brainer" ... you forget why doing it ...Wherever did you find the phrase "because it makes me safe", which you put in quotation marks? I wonder why you assumed I think that? I'm sure I never said it.
A buoyancy aid will NOT keep your head above water - if you get KO'd and fall overboard you're likely to drown - TBH, in a dinghy, getting hit by the boom is one of the most obvious hazards and that could easily knock you out - you wouldn't be panicking .... !! And that's the problem with your "No Brainer" - it seems you haven't considered that possibility.To me it's good sense to back-up presence of mind, ability, memory of previous experience and general alertness, with the extremely simple expedient of making my body unsinkable. That's a no-brainer, because it's effortless and if the day comes when I fall in (never, yet) I won't be panicking half as much as matey was in the video. Personal buoyancy is no guarantee, it wouldn't prevent nasty injuries aboard the boat, nor potentially deadly separation from it if I went o/b...and it doesn't begin to avert countless problems which require the sailor's alertness to be on continuous duty...nor does it instill any shade of conceit to that effect...(not in me, at any rate)...
You seem to think that I'm suggesting you don't wear a buoyancy aid or lifejacket - that's just not true - I just believe you need to know WHY you are wearing it and don't become complaisant whilst wearing it....BUT...if I do ever go in the water, it will necessarily be unexpected - it might be my fault, it might be someone else's, it might be an unforeseen gust or wave...it doesn't matter why, it only matters that by resolving always to wear buoyancy, I will have recognised the potential of the unexpected to put me in the sea, beyond my power to foresee it, and once there, my time will be very short unless I'm attached to something buoyant. What kind of sailor thinks all of that through, and still chooses to risk drowning?
But why do we all need to wear seatbelts? Because there are so many chances of accidents - accidents are usually because someone is driving too fast or too close for the conditions - if everyone slowed down a bit then the chances of accidents would be greatly reduced and the need to wear a seatbelt removed.I don't wear a seatbelt because the law insists, but because I know that most of what happens on the road isn't mine to control...so if someone crashes into me, I'd like to be restrained in the seat rather than fly through the glass or headbutt solid chunks of the cabin.
It's not an either or - you should take all reasonable steps towards preventing the need to use buoyancy - but to do that you need to know the risks, and as I keep saying "I always wear a lifejacket" can make people complacent - they forget the risks...Transfer that to the boat, and there's still every reason to take reasonable steps towards preventing the business of ending up in the water...but as soon as you accept that it can happen, why would you not choose to the benefit from full-time personal unsinkability?
Ah - morning ...Alas, I don't see a point in continuing with this. There seems to be a sort of metaphorical mountain ridge, from either side of which, parties cannot see each other's point.
Sail safely chaps. Goodnight. :moon:
Where as I am also a reasonably good swimmer and went through the swimming lessons including swimming in clothes and have experienced it since. When onboard I wear clothes that are appropriate for sailing - ie no jeans that shrink and make swimming impossible.
If I slip off the pontoon, it is still in a reasonably controlled environment. Not saying that it is not dangerous, but the sequence usually runs - get on board, go down below right away, get changed and put the LJs on. Only then venture back on deck to get the boat ready to cast off. Plus, the idea of carrying the LJs with us back to London every time somewhat does not appeal...Not before then? What if you slip off the pontoon? That seems to be where most of the dangers lie.
Engine on and dump the main halyard doesn't take long - with full lazy jacks the main is contained.
Oh - so you do decide - depending on location and weather ...
Those don't take long to kick off ...I don't wear jeans either, but I don't relish the idea of trying to swim with my MPXs on or Ocean boots, which turn into anchors.
Perhaps you should look at the statistics - people falling off pontoons seems to be a regular occurrence - but your situation will be dependant on the sorts of conditions you go down (cold and wet being the most likely time to fall off ... ) TBH, taking lifejackets home is an inconvenience ... that's a load of rot if you then say "you must always wear a lifejacket in the solent" ...If I slip off the pontoon, it is still in a reasonably controlled environment. Not saying that it is not dangerous, but the sequence usually runs - get on board, go down below right away, get changed and put the LJs on. Only then venture back on deck to get the boat ready to cast off. Plus, the idea of carrying the LJs with us back to London every time somewhat does not appeal...
Perhaps you should get a AWB then ...No, cannot do. The engine controls are down below and although we have full lazy jacks, they are stowed away while sailing. Lastly, being a full blown racer, "Red Machine" has a slotted mast, which makes dumping the main a bit more demanding
Yes - I can - I hope you can too ...When in Croatia there are usually 4 of us on board, no kids and all with thousands of miles worth of experience. If the weather is 25+ Celcius and the water temp is 20+, it means I am wearing a pair of shorts and probably a pair of flip-flops. If I am to go in the drink, unless being hit by the boom, chances are I would have a nice swim, the other 3 monkeys can dump the kicker, start the engine from the cockpit, lower the bathing platform and get me back on board. If the bura is howling, of course we will all be wearing the LJs all the time, despite the general warm weather. I hope you can see the difference...
Perhaps you should get a AWB then ...![]()
When I was sailing in the Solent it was in a 30 or 37' AWB - Easy access to engine controls and a crew who was not distracted by children or pets - we usually sailed in fair weather and as both of us are active dinghy racers, a gentle sail in the cruiser was not taxing - those were some of our reasons for not always bothering to wear a lifejacket - I hope you can see the difference!
That's fine - as I've previously stated - I have no problem with people wearing LJs if they want to - what annoys me is the "It's a no-brainer" statements, and inference that those of us who chose when to wear safety gear are somewhat putting ourselves at unnecessary risk ..Generally I am in agreement with you and I am not saying that one MUST always wear a LJ while in the Solent. It is just my specific circumstances, where I think we MUST always wear one when on the boat.
As to getting a AWB - no way - the JOD 35 is a very comfortable boat for 4, it is a pleasure to sail short handed and is very simple to maintain.
Going over at night in even moderate seas is going to put you in very serious trouble. Another way to look at it is to imagine that rather than being on a boat a few feet above sea level you are sitting on the roof of a caravan which is perched on top of a 10 meter tall scaffold tower.... and its a bit windy... now how do we feel about clipping on?
