How often do you use the BBC Radio 4 shipping forecast?
Hugh, you will read my comments at the end of the completed survey, but I really needed to know what question two really means?
2. Are you a professional within the yachting industry?
I still like to listen to the Radio 4 Shipping Forecast at 00.45 (I'm not an early to bed type) newarly every night when out on the water. Whilst I use modern smartphones and the CG on VHF mainly, the R4 is a back up which is always there. 3G and WiFi is sporadic on the West Coast of Scotland and the R4 forecasts really come in to their own when the CG go on strike! Remember that not too long ago, R4 was our only forecast..
That was when, and why I fitted Navtex. Must admit that I've never had quite the same
feeling for the CG since these times when they were refusing to give out safety information!
Navtex is now excellent on the Scottish West Coast, since they started transmitting from Malin Head, as well as Portpatrick.
That seems like a nasty cheap shot. I have a Nasa Navtex, which has worked perfectly since the day it was installed. It doesn't matter how much you spend on a Naxtex, if it is properly installed, and operated, they all give the same forecasts.
I bought a Nasa Navtex some time ago. It never worked properly. After wasting a lot of time I finally threw it away.
With hindsight I should have bought a Furuno.
However, as we never do passages of more than 150 miles, I now manage without Navtex.
What an admission of defeat! Did you take it up with your supplier? Did you follow the instruction manual? Did you install it in accordance with the instructions? Do you often buy things and then throw them away?
Yes, I did take it up with the supplier. I spoke to Nasa on three or four occasions. They put me in touch with their 'software developer', a pleasant chap to whom I spoke several times and emailed rather more. It was all to no avail.
My income depends on the amount of time I spend working. At a rough guess, the time spent mucking about with this hopeless product would have bought several Furuno units.
It's a question of economics. I don't consider it important enough to make it a matter of principle.
Camelia, thank you for completing the survey and for your comments. The question simply seeks to identify those employed within the sector, and those who are leisure sailing enthusiasts.
And Angus, sadly my local harbourmaster doesn't quite do it for me... He looks too much like Captain Birdseye.
To Pye End (I still have not got usedto this new forum)
It really all depends on what kind of sailing you are doing. If it is only day sailing or short coastal hops, then you really only need VHF. Going off-shore then NAVTEX comes into the essential category. It is a component of the GMDSS. On a number of occasions in my cruising around France, Iberia and the Med I have found that NAVTEX has been my only source of weather information. It is also an easy way of hearing NAV warnings. NAVTEX has its faults and is 1950s technology but nobody has yet come up with an affordable alternative.
But, BBT R4 is the same text as NAVTEX forecasts. As long as the BBC use 200 kc, I guess that will continue. After that? Maybe we will all be able to afford something like Inmarsat satcoms. That really is the only technically feasible replace for NAVTEX
Take care . . . there are others on here that look like that too . . .
never, since the intro of the web. TBH I rarely go more than 12 miles from the shore so I dont want to know what the deep sea forecasts are.
Handsome and distinguished you mean. ;)
To Pye End (I still have not got usedto this new forum) Going off-shore then NAVTEX comes into the essential category.
Frank, I think this is the crux of the matter - NAVTEX will become the much more needed post R4LW as there will be very little other choice.
Many sailors don't neatly fit into one of the two categories of inshore and offshore - sailing across the North Sea every few years, for example, can be comfortable with a LW radio and the expense of NAVTEX not currently justified.
I am, basically, a coastal sailor. My longest passage was 3 day with a fair number of 24 hour to 48 hour ones. NAVTEX has been basically a back-up for weather. Occasionally it has been our only source of forecasts.
More importantly is that it is a source of NAV warnings. We have tried to listen on vHF to French, Spanish, Italian, Croatian etc MRCCs read out warnings in two or more languages, NAVTEX always in English is far easier.
As I have posted already, i hate my navtex- but that is probably my fault for buying el cheapo.
Several of my friends speak very highly of the NASA Weatherman. As I understand it, it receives German weathe rforecasts -Europe wide, I believe - and displays them in a really user-friendly way. I don't think it give nav warnings.
Any thoughts, Frank?
I looked at this a year or two ago and there were significant gaps in areas covered - including the West Coast of Scotland, which I was particularly interested in. This may have since changed.
When we are cruising, and in harbour/at anchor it is a tradition at about 17-50, to switch on the LW radio, pour the drinks, put out the nibbles and listen to the Shipping Forecast. The general weather forecast that follows (unless there is cricket on :mad:) is also worth listening to. We may or may not listen to the 6 o'clock news and then switch off.
We also have Navtex and of course the CG regular VHF Inshore forecasts for our area. We don't have any internet access on board as yet. SWMBO now has an iPad which will be aboard this season and it may provide access to Internet forecasts depending on WiFi access.
