jfm
There is no need to actually start any engine up at all for months.
Quote:- sloosh the oil around and exercise the rubber components (impellers, seals, etc).-:Quote
You can do the job quite adequately.
All you need is an auxiliary Water heater, Oil pump and Barring motor to turn the engine over at about 5 rpm heat up the water, pump the oil around and then run up on the Barring motor for may be 3 to 5 mins at the most oil around everywhere and no build up of carbon the engine and oil stay as clean as a whistle.
Bit like they do on the real thing.
30,000 to 160,000 SHP prime movers.
When I was in the Merch thats the way we always did it with Diesel's and Steam turbines.
100% agreed - if you're lucky or geeky enough to have water jacket heaters and Barring motors!
