Griffin Marine
NiceI'm usually quite religious about checking oil and water etc. This A5 form helps me keep a record on things.
Tim
Now I know the obvious answer is do them daily but do you actually check everything in the engine compartment on every trip out?
To get into the engine compartment in my boat is a real pain!
If we are motoring for over 6 hours i check the oil every 6 hours. We can gain access and lift the dipstick while the Perky is running
I had a similar problem many years ago where the raw water cover looked closed but leaked salt water down the front of the engine. So now when I remove the cover I always run the engine to make sure it is not leaking afterwards and touch the raw water impeller cover is cold, if hot I know water is not circulating. Also I put some Vaseline on the raw water cover seal, it seems to help. Someone on mentioned having clear covers, are they any good i.e. just as strong as the originals and where do you get them.
