How many on a boat?
Tosh.
International Law.
The 12-passenger limit is the product of an international convention that defines the line between a private pleasure vessel and a passenger vessel; it delineates private use versus commercial use and determines the subsequent statutes that must be followed. “Unless your yacht is certified as SOLAS and is operating as a licensed commercial vessel, there is absolutely no wiggle room with the twelve-passenger limit,” says Yacht Management Specialist Lynette Hendry.
It may well be tosh, I thought the same but it depends on who you ask I guess, did you read the other thread I linked to?
Andrew M phoned the MCA, this was their answer:
" I've spoken to the MCA, their advice was that if the boat's not coded (that's run out and I can't see me replacing it) and if the people on board are "friends and family" (there's a definite distinction between this and "passengers" who are fees paying people), and if I'm not using the boat for any commercial type of use (ie, not recovering more than fuel/running costs) then there is not an actual limit on guests on board subject to the fact that it is my responsibility as skipper to ensure the vessel is seaworthy and safe to use, that there is adequate safety equipment on board for all persons etc. "
JFM's post on the subject is very informative:
" I've only just seen this thread. You've touched on a very complex topic, and one I've had to think about carefully because I run an 80 foot private non charter boat that is CE plated for 20 people and can easily fit that many people for day cruising and I get plenty of requests from friends for >12 passengers.
Sorry this will be a long post - you need to blame the legislators for making this so complex
Excuse the bluntness, but a very large part of what is written above is just incorrect. Just as a couple of examples, the "12+2" is fantasy, and MGN 538 neither "definitive" nor "legislation" because it is not law. The reference to mgn280 is merely half of that story: if you want to code a boat you have a free choice in UK to code to mgn 280 or yellow book (and fwiw I cannot for life of me see why someone would choose the more awkward mgn280).
When seeking advice from MCA, RNLI and RYA, remember the second 2 are giving merely an opinion that you can't rely on. Even if you are asking the MCA remember (a) under Uk law advice from a public body such as MCA may not be relied upon unless you ask your question in a particular format (the legal precedent is MFK Underwriting and then the Matrix v CIR case) and (b) this topic is so complex it is unlikely a front line question answerer at MCA will even know the answer (but i'd be delighted to be proved wrong there)
The legal analysis goes like this:
1. Mgn538, which isn't law, says that in UK law a private vessel (by which I mean not commercial, under the SI 1998/2771 definition) carrying >12 passengers is a "passenger ship". The basis for that assertion is that SOLAS says it, and SOLAS is sort of adoipted into UK law in the various shipping acts. However, SOLAS doesn't actually say that in clear terms. Solas grants an exception to passenger ship status if the vessel is in private use, but then elsewhere it says >12pax = passenger, so SOLAS itself contains an internal inconsistency. STCW, also incorporated into UK law on a similar footing to SOLAS, doesnt contain that inconsistency: it is clear under STCW that if the use is private then the boat isn't a passenger ship even if >12 pax
2. So you start from a position that the law is defective. That aint unusual, btw
3. you could just leave it at that and run the boat not as a passenger ship, even if >12 private guests, and you'd likely be fine
4. But let's say we want to be cautious, so let's cautiously assume the SOLAS inconsistency ends up in a decision by MCA to treat the boat as a passenger ship. (Remember MCA is a prosecuting authority in its own right, like the CPS; it doesn't need the CPS). Then what?
5. Well now you're into more complex law. First, virtually all the rules for passenger ships don't apply in the cases applicable to this forum ie boats with <80GRT and not on international voyages. The rules get tougher the bigger and more offshore-ish and international you go. The MOST that could apply to "our sort of boating" as I read the law (and I repeat, it is complex) is that you must have just 2 certificates: a safety certificate and a safety management certificate. I think you would get those easily enough from a surveyor assuming you ran a good vessel. So that's your worst case scenario, and it aint too bad
6. But that is pretty conservative imho. A more balanced view is to say that the vessel must be "coded" under the applicable code, which isn't mgn280 or yellow book or any of the commercial codes but is the slightly obscure "Passenger Yacht Code", which has been adopted by the red ensign group ie by the UK. This code contains all sorts of rules about watertight bulkheads and stuff, but NONE of its rules apply to a boat built from GRP not in commercial use.
7. My conclusion therefore is that for purely private use you can have 12+ passengers on a GRP UK flagged vessel in coastal cruising and still be compliant with UK law, subject to #8 and #9 below. I'm therefore disagreeing with you that there is a meaningful change in status once you exceed 12 pax
8. All of the above is subject to the general legal and tortious duties of seaworthiness, adequate safety equipment, not overloading, etc (NOT, in law, a nameless "duty of care" as people keep writing time and time agian, misunderstanding the meaning of that phrase in UK law). Those are all things you must apply your own judgment to but it's not hard and my personal view is you should (a) not exceed the CE plate number, (b) have enough LJs and lifeboats for those on board, and (c) generally keep the boat in decent nick and navigate it sensibly. In my own case I have enough LJs (20+) and I consider that the total plated capacity of the LRs and the tender (8+8+7 in my case) to be the relevant lifeboat number, for ordinary coastal day cruising with chums.
9. All of the above is ALSO subject to the UK regulations (ie, law) which are similar to what I write in 8 above except that on >13.7 <24m boats you must have LRs for everyone (ie not rely on the tender) if >3miles from the coast. Therefore when I have >16 folks (incl crew) on my boat I stay <3 miles from coast, but that is fine for day trips and local easy peazy cruising
I'd be interested to hear what MCA, RNLI and RYA actually say about this complex topic. I think you should have spiced up your question to specifically draw their attention to mgn538 where it says >12 = passenger ship even if no payment, just to make them work a bit harder :). "
You'll be glad to know I've just put a deposit on a Bayliner. Twin engine 7.4 mercruisers / twin outdrive as recommended. Perfect for my end of the Thames!
Hahahahaaaaa! Good to see you still have a sense of humour/ are really as thick as two short planks*
So, really. What's gwaan on? Got anywhere with the boats you have seen so far!? ;)
* delete as applicable! :p
Only joking, still looking, hoping to get over to penton hook this week to jump aboard some "proper boats" and see what takes my liking, still looking at the Fairline Mirage aswel even though out of budget i didn't realise the boat market was more like the housing market when purchasing (especially with so many brokers)
I've bought and sold my fair share of cars over the years and depending on the initial value it's true you'll never negotiate more than £1k - £2k as an absolute maximum (condition dependant etc)
I was surprised to hear that a substatial offer under an asking price is often considered at this time of year and well worth a try.
So with that in mind I've first got to find what takes my fancy and start putting some offers in!!
A % of the budget is going towards mooring, I've had a general look around, do you pay monthly? Annually? Any recommendations on what made you chose your place of mooring?
I live in sunbury on Thames so local to me is shepperton marina and Walton Marina
Thanks again all for all of the input, I don't know any boaters personally so was ideal for me to join here and do the research!
Both the marina's you mention are nice enough, but Bray and Windsor are IMHO better placed!?
The Mirage is a good boat, but I always found the tricky thing is that the better Aft cockpit version tends to be Petrol on Outdrives, while the Aft Cabin version is usually Diesel on shaft. Both good though, but the Lytton is the best of both, and cheaper.
A twin 7.4 Binliner would be horribly good (scary!) fun if such a thing existed though :cool: (Not with a 5mph limit sadly)
Reckon £3500 mooring, £450 River licence and £250 insurance, then £500-1000pa looking after it if you get a good one.
:encouragement:
Was not that the model of boat featured in the on-line boat mag as a half decent livabord.
The larger Bayliners were the complete antithesis of their smaller namesakes in that they were well put together from materials that you could put near water and which did not immediately start to dissolve.
In their defence (for once) they seem to last OK.
Which is a shame in some ways :ambivalence:
I don't mind 'em, but they need to be on a lake. In America.... :encouragement:
In their defence (for once) they seem to last OK.:encouragement:
Did look at several in the last century.The 25ft Regal that ended up absorbing every last groat I possesed ,ensured my loathing about this type of boat.
It boasted twin petrols with outdrives and Flexy deck construction.
A constant battle to keep it going because of awful electrics,self destructing outdrives and wall paper paste used to hold the interior together.
The best thing was the Teddy Bear Fur used to line the fore cabin,it probably was the only thing holding the boat together.The final straw was the wood (MDF) ? used to reinforce the stern,turning slowly to a pulpy mush due to water ingress.
There was of course no way of getting to front of boat without clambering across the highly curved and slippery cabin roof which buckled alarmingly as you scrambled across.
Happy Daze. :)
