carrswood
my electrical knowledge is limited - could you help me with some calculations.
When I have some money saved I intend to replace my 12v fan cooled fridge box with a more efficient external compressor type (isotherm, waeco etc).
In the meantime could you help me with my current fridge:
12V supply
Consumption = 46W. Therefore am I right she's using 3.8 ah ?
NB: this fan cooled fridge has no thermostat - so its always cooling and constantly drawing 3.8 ah.
But, the good news is an overnight test and thermometer inside showed a temp of 2.2 degrees (more than cold enough).
My question is, if I was to connect this fridge to a dedicated 120ah battery for the fridge only - how many hrs use could I run it for?
My understanding is a good quality battery should not reach a state of charge less than 50%.
My simple maths would say I would have 60ah of usable battery life to utilise - ie 15.8 hrs running. Now I know it doesn't necessarily work like that!
. For one the current is perhaps weaker in the latter stages and the more you de-charge the battery then the longer it will take to re-charge the battery with your alternator.
Could someone help me here with the True facts I should be aware of?
12V supply
