mil1194
Known on our boat as the 'orange mooring line', useful if within the hearing of others and there is a shortage of sockets.
Just don’t forget to ‘unattach’ the orange mooring line…. ?
Don't tell me you were there.Just don’t forget to ‘unattach’ the orange mooring line…. ?
Don't tell me you were there.![]()
As Poignard says.What's the bow fender for?
In my defence, I will say that it only happened once, at Den Helder. We had cast off all our lines when one of us noticed that the orange one was still connected, but fortunately I had not yet engaged gear. I would swear that there was no-one around.There’s always SOMEONE watching unless it was a seamless takeoff/landing.
I recently bought a new (to me) sailboat, 32 feet. It came with 4 fenders only. In my view, with my manoeuvring skills, not enough.
so it made me think, apart from the obvious answer of “you can’t have too many”, what would be an acceptable number and would a big ball fender be necessary?
That is very true. The boat should be making no progress fore or aft when finally alongside, having come to a halt a short distance off, even a few inches. This is not always easy to achieve, but should always be the rule when approaching another boat. Unfortunately many sailors seem to think that they are devices designed to add friction to assist in stopping their boat, with little concern for the state of my topsides (or good humour, if there is any left).You say "maneuvering skills."
Ball and oblong fenders get pushed out of the way and snag on pilings if you are still moving. Rub rails or some manner of long pad might be more useful. Suggestions?
I never think in terms of fenders for maneuvering. They are for tying up, once I am positioned. The idea of crew moving them around is impractical, since I singlehand much of the time, or sail with disabled (or not agile) crew). Either way, it's just me to put the boat against the pilings just so.
And if you feel you need more, hang more. Forget the comments from the peanut gallery and do what works for you. Pride matters less than dock rash.
This is why coming alongside or leaving in difficult conditions is such a great spectator sport - from a safe distance!That is very true. The boat should be making no progress fore or aft when finally alongside, having come to a halt a short distance off, even a few inches. This is not always easy to achieve, but should always be the rule when approaching another boat. Unfortunately many sailors seem to think that they are devices designed to add friction to assist in stopping their boat, with little concern for the state of my topsides (or good humour, if there is any left).
The latter, i have oneWhat's the bow fender for? I often see them and wonder whether it's upcoming anchor damage protection or can't stop in the finger berth before hitting the main walkway. Which is it?
+1 fender boards.38' cat
Fender boards cover a multiple of sins.
I made one from a long beam of marine ply with 20mm closed cell foam, glued, on one side..
The length of a fender board, or a combination of same depends on the size of your yacht
we also carry 4 fenders and one ball buoy fender
We moor to our own swing mooring, we don't use marinas - our only need for fenders is picking up crew (and a lot of our piers have poles - hence fender boards) or refuelling (and normally we refuel with jerry cans (its cheaper).
Jonathan
I have one but I prefer a slightly beefier one I bought later, very similar shape. It s quite useful for maneuvering alone: engine in slow forward with the bow resting against the pontoon and the rudder to push the side to the finger, you can take off all mooring lines the boat will not move, then reverse and off you go. Also useful when arriving, need just a bit of judgement for the distance bow/pontoonAre these things any good?
Haven't got anything for the bow but was debating one of these or one off the y shaped buoys
I have one. it has never been tested in anger so can't really say. We used to have a V shaped one but I didn't like it as whilst psychologically it was reassuring for entering fingers of uncertain length, in practice the height of the pontoons varied enough to risk invalidating that benefit. These long ones seem to address that range far better (and IMHO look a bit better too). It also seems to discourage the crew from tying the boat up quite so far forward on the finger which is good IMHO.
