gregcope
Hi all
Fours years?
What if they get damp/corroded?
Fours years?
Fours years?
I've heard that the 'rubber' is attacked by diesel. Is that correct?
I have diesel on the loose around the engine (e.g. recent prolific injector pump leak; escaped diesel when changing horizontally mounted secondary fuel filter etc.) far more often than I have fire (thank goodness).
It is difficult to be specific. Natural rubber has the best vibration damping characteristics but the worst resistance to attack by hydrocarbons. Engine mounts in this elastomer usually have a dome of steel as the upper part to shield the rubber from attack.I've heard that the 'rubber' is attacked by diesel. Is that correct?
P.S. Though they may last many years, even decades, I presume they tend to gradually compress during that time and therefore require occasional adjustment to maintain proper alignment?
Aside from the smell, those diesel leaks shouldn't affect your engine mounts.
I have a BUKH DV10 engine. The port aft mount is below the fuel filter and if there is any leak of diesel the mount soon deteriorates. After curing the leak that existed when I bought the boat and fitting a new mount, I had another one fail within a few years due to my being careless and not washing off any diesel spilt when changing the filter element. Access to the filter is very restricted and it is easy to spill diesel when removing the bowl.I had a fuel leak on the BUKH in my old boat. I bought her when she was about 5 years old, no idea how long the leak had been there, probably a year at least. One mount had swollen and gone very soft. Certainly a result of the diesel.
Yes, also by oil, which is a real problem with older engines which tend to develop minor oil leaks.I've heard that the 'rubber' is attacked by diesel. Is that correct?
