Roberto
Of course not, I said the friction of the chain in the water dampens the lateral yawing, which is given by the combined effect of aero and hydro resultant forces and their respective points of application.Well, but it is not the friction of the chain in the water that causes this. Just compare the surface area of the chain with that of the boat. The latter is orders of magnitude larger than the former, and so it is mostly the friction of the boat that will dampen the system, not the friction of the chain.
Bring the hydro forward and the the aero aft and the system stability increases, leaving a long loop of chain under water at the bow contributes to bring forward the point of application of hydrodynamic forces hence contributes to yaw dampening.
Just to be sure we are talking about the same thing: I am referring to lazy chain going over the davit roller, into the water, then upwards towards the immersed claw/hook/whatever of the snubber, then being under tension forward to the anchor.
An amount of chain all amassed and tied to the snubber claw with nothing going to the boat would have a much less relevant hydrodynamic effect and would mostly act as a kellet.
