Twister_Ken
My 3YM20 has just passed 500 hours. Local engineer is quoting 7 hours labour for the 500 hour service. As far as I can see, the 500 hours is a normal service (change oil, oil and fuel filters, clean air filter, change impeller, check (and drain if necc) water and sediment from fuel tank, adjust belt tensions, check electrical connections). In the past this has taken about 3 hours. The only exceptional item at 500 hours is to replace the injection elbow and gasket. Is the injection elbow anything like a 3-4 hour task? I should add - access to the elbow is not impossible but it is cramped.
Thanks in advance for any advice.
