GHA
Carrying on with the never ending refit......
Leaks under the mast and nasty rust, can't have that now can we![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So over a dust buster beer the next cunning plan in the quest for no holes anywhere is more plate with studs welded to the deck which the mast foot will attach to, but why not go further!
What about 2 plates hinged then if there's ever a need to drop the mast it can be done easy enough.
Means dropping the mast first to get at the deck, looks like there shouldn't be any major hoops to jump through, load of dyneema onboard to make up tiebacks & guys plus day job used to be lifting things an awful lot heavier so what could possibly go wrong...![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Very vague plan - use whisker pole as compression member either attached to bottom of track on mast or maybe weld a bracket onto the deck.
Use windlass as a hoist, maybe double reeved to keep the speed down.
Looks like it will hit the boom gallows first so maybe a temp something above the radar arch or on the mast so both touch together. With a laser & CAD this can be plenty accurate.
Very rough sketch just to get started below.
So the questions:
How heavy is a 12m single spreader mast? Guessing somewhere between 80Kg & 120Kg but instinctively prob less, best to guess high.
For those who have done it - was there a "Ohh, didn't think of that" bite on the bum moment? Or tips for an easy and happy mast lower experience?
Big TIA as always
![Yghy3Kw.png](https://i.imgur.com/Yghy3Kw.png)
So the questions:
Big TIA as always
