RobBrown
Replacing an agglomerator with a CAV filter/bowl, which has four ports (in & out on both sides, with 2 blanks) instead of two on the original (one in one out). The in port feed (ie from tank into the new unit) is on the outside of the head unit, so is about 1 1/2 - 2" further out from the bulkhead than the current fitting. There is little fore and aft movement of the connected pipe in the exisiting set up and I am worried that moving the pipe laterally out onto the fitting on the new head might stress it unduly. Any opinions, advice or suggestions? (It is copper fuel pipe from the tank right up to the nut union on the agglomerator, no flexible pipe work)
