how far on 35 gals diesel Yanmar YSE12hp
sabresailor
5 Oct 2003
Somerset
I have a 35 gallon tank on my Sabre 27 which has a Yanmar YSE 12 hp diesel engine.
How many hours of running would you estimate 35 gasl equals??
I know this will depend on revs etc - but assuming 'average revs'.
Cheers
Mike
johna
12 Aug 2001
Poole
Mike
Are you sure you have 35 gallons most Sabres have about 12 gallons.
Consumption of the YSB 12 is about 3-4 hours per gallon at 4 knots say 12-16 NM per gallon.
sabresailor
5 Oct 2003
Somerset
Hmmmmm - will have to check - to be honest - I just took the 35 from the sale particulars haven't given it any thought!!!!! (bought the boat 1 yr ago) + will measure the tank (cube shaped)
Thx for your help tho'
Mike
uforea
5 Nov 2001
Leics.
I have a YSE 12 on my boat (ufo 31 with folding prop) and when I bought her the sales blurb said 3/4 hrs per gallon. I have found that running at about two thirds throttle I get roughly 8/10hrs per gallon, this gives me a speed through the water of 5 or a bit more knots. Maybe the quoted figures are for full throttle????
Ted.
Talbot
23 Aug 2003
Brighton, UK
I would be amazed if a 12 hp uses as much as 3-4 gallons per hour. I suspect you meant abt 3 litres per hour, and even that is probably at approaching full throttle. I have a yanma 27 hp diesel outboard and that uses 6.5 litres/hour at full throttle (4500 revs), and abt 3 litres per hour at my normal cruise speed (3500 revs) - taken from Yanma installation manual. For a 12 hp engine I would expect you to have a 12 gallon tank unless the boat has been modified to have a long range tank.
sailorman
21 May 2003
Here or thertemp ashore
if u re-read the 2nd post it was 1 gall = 3 to 4 Hrs motoring for the Yanmar YSE 12..
i used to have the YSE 12 in my Co 32 its a very robust engine just watch-out for fuel on the Stbd flexi engine mount that has the injector pump directly above it
i manage 3.5 > 4 Lts per Hr @ 2400 rpm ( Nanni 4150) 7Kts cruising spd
snowleopard
Oxford
engines are pretty consistent in the consumption per HP per hour so here's another input: my 27's use 2.5 litres per hour each at 2750 revs. i would therefore expect a 12 to use around 1 l/h or say 5 hrs per gallon
EdEssery
5 Sep 2001
Berks.
I have always been led to believe that most Marine diesels of whatever size comply with the following formula - plan on 2 litres per hour consumption per 10HP, if you're gentle and the sea is smooth you may only use 1 litre per hour per 10HP but when planning assume you will use 2. Always worked for me (Volvo 2001 with a 45 litre tank).
Ed
supermalc
14 Dec 2003
Lincolnshire.
As a few will know, I have a YSE12 on a Mahogany Clinker I bought the end of last year to use mainly on the river Witham.
After much investigation I have learnt these engines need to be run around 85% throttle. I have got my boat ready in time for the season, and despite a few 'teething troubles' the engine, which I believe has been recently reconditioned, runs sweetly around this throttle setting. I've yet to find the fuel consumption, but believe I used around 1 to 2 litres an hour. I've had a dripping return pipe, finally found the cause to be from the banjo on the injector. Plus I mistakenly topped up my small tank with the 2 stroke. Was rushing to set off with another boat that had problems. Won't hurt the engine, but the fuel lines developed an air leak, so on my trip on Saturday I continually topped up. Even with leaks, bleeding etc. I think I've used around 2 gallons in 6 hours.
Oh, and despite buying 2 left hand props, still looking for the correct one, which I believe I need a 14 x 10 left hand with a 1 inch shaft, standard taper. Only paying around £30 for them so can resell, even if at a small loss, or just use as ornaments.
<hr width=100% size=1>Malcolm.
<A target="_blank" HREF=http://www.angelfire.com/rnb/malcsworld/>http://www.angelfire.com/rnb/malcsworld/</A>
Take a look at my boating pages.
salamicollie
7 Mar 2002
Cheshire
Had a YSB12 (basically the same engine) in my Cobra 850 - I averaged 1.1l/hour for 5 knots but when the seastate built or with a head wind it could go up to 1.5l/hr - this gives a 30hr range on a 10 gal tank - mind you your fillings will be loose after that long...
jackho
22 Mar 2003
Just a word of caution - whatever the capacity of your tank and your "mpg" just remember you can not depend on putting this to the ultimate test. Remember it is unwise to run with a tank less that 1/3 capacity as you will risk drawing in air in a seaway.
I had this problem and it was not an experience I would want to repeat. Always top up sooner rather than later and carry spare fuel.
You may appreciate this already but better to be sure if it helps.
Jackho
