bigwow
Has to be tight or you loose the Sky TV signal.
In case of interest, I have found in the past that a snubber to take the shock out of mooring lines can be improvised using a standard car roof-rack style bungee strap.
Simply form a loose bight of the mooring line, and tie the bungee tight around the line with a rolling hitch or similar either side of the slack.
Takes a bit of trial and error, but works surprisingly well if one is in a snatching situation; which can of course be quite horrible on cleats, boat & crew !
The majority of boats are moored up badly in marinas by having both springs going to the mid-ships cleat on the boat. Far more preferable to do the job properly by taking springs from fore and aft cleats on the boat to pontoon cleats, so that they not only stop the boat going back and fore but also help to keep the bow and stern alongside.
That's a good theory, but in practice on my boat this would mean lines fouling on hull and giving unnatural lead from cleats across toe rail.
I have all my lines tightish, If I'm on the boat and it's snatching I double up with some scabby climbing rope which calms things down
There speaks the voice of zero experience cruising a 22' boat then !![]()
Climbing rope isnt exactly stretchy, so more likely to snatch. Just like peeps using old sheets and halyards ... which is another thing that niggles me!
You what? I wouldn't want to fall on your climbing rope if it doesn't have any stretch in it. The eyes water just thinking about it
I agree that length is the deciding factor. Long lines, eg springs, can be tight, short lines, breast ropes in a marina, must have a bit of slack. If the breast ropes are tight then even a slight roll causes snatch, which is not the case for the long springs. I think it's a good idea to rig your breast ropes through a fairlead and across to a cleat on the OPPOSITE side of the boat. So I am moored starboard too, but cleat off on the port side. The extra length absorbs a bit of snubbing.
Guilty of midship cleated springs, which are tight to stop me surging around. Over a knot of tide runs through the berth at springs, which makes getting in and out (especially out) interesting, particularly in a long keeler which steers like a supermarket trolley astern.
