How do I connect chart plotter to tiller pilot?
mdonnelly
14 Dec 2003
Bangor Co.Down
Have a Lowrance 5150c plotter and a Simrad TP22 tiller pilot. Got the nmea cable for the plotter which has 3 wires: Orange (receive), yellow (transmit) and a black (shield) wire. The TP 22 has a red(data) wire and a blue (common) wire. Can anyone advise how I join them?
Thanks, Mark
alan_d
15 Mar 2002
Scotland
Do you mean which wires to join together? If so, yellow from plotter goes to red on TP and black from plotter goes to blue on TP.
mdonnelly
14 Dec 2003
Bangor Co.Down
Made the connections, but nothing happening. Created a waypoint to go to, pressed NAV on TP22 but no light came on to say it was working. What are the possible problems and solutions?
mdonnelly
14 Dec 2003
Bangor Co.Down
Have you configured the Com Port to output the relevant data?
Unfortunately not sure about this and manual not really helpful. There are 5 boxes to check under configure nmea:
GLL transmits Lat and Long
rMC and RMB transmits navigation info messages
APB transmits autopilot info
GGA transmits time position and fix data
GSA and GSV transmits fix mode DOP values and satellitesvin view info
Under communication port the baud rate is set at 4800 and there are 3 check boxes:
Nmea 0183 input
Nmea 0183 GPS output
Nmea 0183 output
Not entirely sure where to go!
David2452
6 Jun 2001
London & Fambridge
Thanks everyone, last question; what cable is required to join them?
The appropriate cable to comply with NMEA standards is multi strand twisted single pair screened cable of around 22AWG, ground the screen at the talker (i.e. plotter) end only, you can of course use any twin cable but to be sure of continued and reliable operation the spec I mention is the correct one and will give consistent results, should you have difficulty sourcing small lengths of the proper cable I have hundreds of metres in my store.
mdonnelly
14 Dec 2003
Bangor Co.Down
Really going to show my lack of understanding now! Please explain 'ground the screen at the talker end only'
David2452
6 Jun 2001
London & Fambridge
The plotter is the talker in this case and the screen is the braided cable similar to the outer of a coax cable, this should go to the vessel's Rf ground, as most people do not havel a separate RF ground the DC ground will suffice.
pvb
UK East Coast
Nmea 0183 input
Nmea 0183 output
OK, you need to check the box to transmit the APB sentence, and the box for NMEA output.
